I have this GPU: ASUS GTX 1080
And this converter: Goobay MMK ADAP DVI F > 15 pin HD M (VGA) DVI-I 15 VGA HD M
And this monitor: Samsung S22D300NY
The question is, I am using a DVI-D single link to DVI-D single link. The converter is connecting into the monitor and the cable goes from my GPU to the converter which goes into the monitor. It does display on windows and the monitor does register as working since it does not give the signal that says that nothing is connected. The screen is black.
What would the solution be? Can I buy a HDMI to VGA converter instead? (The port is [RGB-IN])
(So the order is DVI-D in GPU, to converter, to monitor)
