monitor won't light up - need help *updated
dxhcom
16
A week or so ago, my computer began to have some video card issue. The monitor would not light up even when the system normally booted. Recently, the situation became worse. It won't boot no matter how many times I pressed the button. If I first pressed the power button, it stuck on 92 code (PCI initialization). I pressed again to boot, and it stuck on D6 error -No Console Output Devices are found. Sometimes, it can fully booted, and then it works fine.
I reset the CMOS, but not working.
* updated
Moved card to another PCI slot. Similar issue. The system was up. I heard the windows loading music and even my Skype login sound, but the monitor showed no signal.
System works fine when I unplug the video card, and use the integrated video card from CPU.
Here is my configurations. Recently I upgraded the mb and cpu. It worked smoothly for a month. I really have no idea what triggered this.
PSU CORSAIR|CMPSU-650TX 650W RT
Z97-Gaming 5 1150ATX Intel Motherboard
Core i5-4690K 3.5GHz LGA 1150 Boxed Processor
ASUS HD7850-DC2-2GD5-V2 Radeon HD 7850 2GB 256-bit GDDR5 PCI
8GB Corsair VS2GB1333D4
Monitor DEll U2312HM
Hard Drive: M4-CT256M4SSD2
Hard Drive: Samsum HD103SJ
Need some help!
Thanks so very much!
I did some research. It means the system cannot detect my card. But I don't know which component has issue, video card, motherboard or something else?
Video card RMA back. They did not find any issue with the card. They did 48h stress testing.
I installed the card back and have the same issue as before. So frustrating.
Maybe there is some compatibility issues with motherboard/vga card/monitor?
