Hi!
I recently bought a third new monitor to my setup. I have two 60hz monitors and one 144hz. My videocard have 1x HDMI output, 1x DVI output and 3x DP outputs.
What I have to do is run the 144hz with dual link DVI as this is better for this monitor (there's no DP connection to the monitor) and as I only have one HDMI output I need to use HDMI to DP on the other 60hz monitor.
I used to have only two monitors, one of them where connected directly with HDMI and one with HDMI/DVI adapter. Now I use HDMI/DP adapter on one of them. I had them overclocked to 79hz just fine. But with the DP adapter it seems like I cannot overclock to more than 70hz on that one monitor. Do you know why?
I am sorry for the bad formulation...
