Monitor won't power on through HDMI port.
Newb210
11
I checked just about everything, even switched monitors to if it was the graphics card or hdmi cables but no, the other monitor turned on just fine. And it doesn't power on through dvi or vga either. The monitor does work but I just need to turn it on manually. Any help would be greatly appreciated.
My setup:
ASUS VS Series VS228H-P Black 21.5" 5ms HDMI Widescreen LED Backlight LCD Monitor
EVGA GeForce GTX 1050 Ti SC GAMING
MSI H110M PRO-VD PLUS LGA 1151
G.SKILL NT Series 8GB 288-Pin DDR4 SDRAM DDR4 2133
Intel Core i3-6100 3M 3.7 GHz
Rosewill Stallion Series RD450-2-SB - 450-Watt ATX V2.2 Power Supply
Win 10 Pro 64-bit
The monitor works perfectly fine with any cable connected, it just doesn't power on through them. I don't think is the gaphics card only because I use a PS4 with this monitor and it still won't power on through hdmi.
When I have the ps4 connected through hdmi, once I turn it on, it also turns on the monitor. that is not the case for the pc.
It displays the ps4 and the pc just fine, only that the monitor turns on when I power on the ps4, not with the pc.
Correct. I switched monitors thinking it might've been the gpu, but no. Tried changing hdmi cables, that wasn't it either.
