Monitor won't stop flickering
You monitor will have a maximum refresh, you can go lower the refresh in Windows in the nVidia Control Panel. The monitor reports to WIndows what refresh rates it supports. For instance mine has a maximum refresh of 60HZ, but it also supports 59 and 50 Hz. You can't change the refresh on the monitor, just in Windows. Does your monitor have an OSD? If so, does it look corrupted too?
Tried them all besides the DVI cable, as I don't have one with me right now, I'm gonna give it a try later.
60 Hz, can the refresh rate be changed for this Monitor? Haven't come across any settings/options to change the refresh rate.
