Monitor won't turn on with my pc
Newb210
11
As the title says. My monitor won't turn on with pc. It's a brand new build. The only way I get to turn it on is manually. Even when the screen goes on sleep mode, I can't mange to turn on monitor with keyboard or mouse. I went to the bios and enabled wake up through usb ports but no avail. I also have it connected through hdmi. Tried the cable on another device but it seems to work fine. Made sure the gpu was seated correctly and nothing. Unplugged the monitor from the outlet for 30 secs to do a reset and still nothing. Any help would be appreciated, thanks.
My setup:
ASUS VS Series VS228H-P Black 21.5" 5ms HDMI Widescreen LED Backlight LCD Monitor
EVGA GeForce GTX 1050 Ti SC GAMING
MSI H110M PRO-VD PLUS LGA 1151
G.SKILL NT Series 8GB 288-Pin DDR4 SDRAM DDR4 2133
Intel Core i3-6100 3M 3.7 GHz
Rosewill Stallion Series RD450-2-SB - 450-Watt ATX V2.2 Power Supply
Win 10 Pro 64-bit
