Monitor always working and turned right on when i turned on my laptop today monitor wouldnt turn on with laptop and when I hit the turn on on right side of monitor manually the light on front of screen doesnt come on neither doe the monitor?
Please make sure the outlet has power, the monitor is still plugged in...
If yours uses a power brick then you can test the voltage coming out of the end that plugs into the monitor if you have a voltmeter.
