I found an older motherboard and graphics card and decided to put the into my comupter to see if they work but they did not the issue i was having was the monitor wouldnt turn on but the computer turns on and everything, well i changed back to my original motherboard cpu and graphics card
(Gigabye ga-78, gtx 1050ti msi, amd fx 4300)
And the problem has consisted through the hardware change if you can help in any way that would be extremely helpful
