Question Monitor won't turn on
shanyin37
113
Hello.
My monitor VG248QZ won't turn on when I turn on my system.
I have to restart several times to get it to work. I is hooked by a display port and a power cable.
Windows 10 home
won't turn on\power up or won't come out of standby mode?
if it's not turning on, then you have a hardware failure with the display itself.
make sure all power cables are firmly attached. if doesn't help, test with a different power source.
if it just won't come out of standby mode, than it's more likely an issue with your GPU or other system hardware.
