Question Monitor won't turn on ?
dalibor19901
22
Hello. So my monitor won't turn on. And if it were that simple, I'd just get another one. But the thing is, after messing around with the cable, stroking it and twitching, it finally turns on, but the resolution is lowered and there is no sound. Every time. And then I have to disable/enable display adapter and switch the sound between headphones and stereo to make it all work again. I mean, that clearly got nothing to do with monitor, right? However, even when the computer is off and I only turn the monitor on, the problem occurs anyway. The neon light goes on and off. I tried changing the cables, I switched to another wall socket, none of this helped. I have a ViewSonic monitor, 1920x1080 resolution.
