New to posting and the title pretty much sums it up. When trying to wake up my computer with my mouse or keyboard the computer turns on and the monitor turns on with a blank/black screen but after a few seconds it says "no display port detected" or something to that effect. Which at this point I have to restart my PC and then the monitor runs normally. Unfortunately this issue seems to have started up a few weeks ago. I've had this monitor for around 3 to 4 years, and the rest of the system for about 1 year. I've tried searching google and other forums with no luck. I'll post what I've already tried to fix it with no luck and my system specs below. Any thoughts, tips, advice would be helpful. Thanks
In the ASUS Monitor settings I've unchecked DisplayPort Deep sleep (turned it off)
Turned off Windows Fast Startup
Have my Windows 10 power settings set to High performance
Updated all drivers and windows updates
I'm using the displayport cable that came with the monitor but I've ordered a new cable and will try that. I currently don't have another monitor I could test to see if it's a faulty monitor.
Monitor ASUS PG279Q (not overclocked, set at 144hz 1440p, OD set to normal, connected via displayport)
Intel I7 8700k
EVGA Z390 FTW
EVGA RTX 2070
Corsair Vengeance LPX DDR4 3200mghz 32GB (4 8BG sticks installed)
Samsung 970 Evo 500GB (OS installed here)
Samsung 970 Evo 1TB
Windows 10 Pro
Intel I7 8700k
EVGA Z390 FTW
EVGA RTX 2070
Samsung 970 Evo 1TB
Windows 10 Pro
