T TJ____ Reputable Dec 1, 2015 3 0 4,510 Dec 1, 2015 #1 I have a GTX 960 and I've tried hooking up my monitor every way but still wont pick up the connection. I have a VGA cable and DVI to VGA adapter to work with. Any ideas how to fix?
T TJ____ Reputable Dec 1, 2015 3 0 4,510 Dec 1, 2015 #2 The problem has been solved. I just need to use a DVI-D cable to the monitor. Upvote 0 Downvote
T TJ____ Reputable Dec 1, 2015 3 0 4,510 Dec 1, 2015 #3 The problem has been solved. I just need to use a DVI-D cable to the monitor. Upvote 0 Downvote
