Monitor Working When Motherboard Plugged In But Not Graphics Card?
John Sawyer
26
When I plug my monitor into my motherboard, the computer runs displaying everything fine. However, when I try to plug the monitor into the graphics card, the monitor doesn't show anything. The fans on the graphics card are spinning but they just won't work. It is a GeForce GTX 750 Ti graphics card. There are no inputs to connect the graphics card anywhere else... Help!
i would suggest to check the gpu on any other machine as it doesn't require any external pci-e psu cable so will be an easy task. Next step you can try is clearing out CMOS and check the results. Good luck :)
Here are couple of things you can try:
1) Update UEFI or BIOS to the latest version of your motherboard.
2) Ensure the GPU is plugged in properly(Clean the pci-e slot, if needed).
3) On your monitor, make sure you have selected right input cable settings.
4) Try the GPU in a different PCIe slot.
1.Tried to install but I don't know what to click within the file.
2.Already checked it is in place.
3.It works on the motherboard and I used the same cable to try the motherboard and GPU so I know this is correct.
4.There is only one PCIe slot in my motherboard.
For BIOS update, download latest BIOS from asus website: http://www.asus.com/uk/Motherboards/H81MD_PLUS/HelpDesk_Download/and put onto a formatted USB stick
Then follow these instructions:
Dude,
I had exactly the same stupid problem. I tried all the solution that posted on the net but it didn't work. So I come up with new solution, Just reset(Reboot the pc like a new pc). Don't plug in your GPU first,use your motherboard graphics during the reboot,after all is completed then try to plug in ur GPU. Hope it works. this what I did
This problem occurred because of the software in your pc that affect your bios to corrupt. Do it as fast as possible.Just reset.
