Question Montech King 95 Pro
akhandyman
19
Not seeing my issue with this case on the internet anywhere, so throwing it out here. I have bought a few of these cases and built PC's for customers. However on the one I finished last night, the rgb goes back to the default color (solid bluish white) every time the PC comes out of hibernation or is turned back on. I have built in this case before and on the previous builds those rgb settings stay locked in until you select the button on the case under the power button.
I've sent a support ticket into NewEgg and Montech and thought I would see what anyone else has experienced. I know if I was taking the time to set up my rgb and had to redo it everyday, it would be annoying.
Thanks
Are all the system's innards the same for all PC's?
Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
If so, then one set of specs will help. If not, then you will need to verify which one's are the outliers. Perhaps your motherboard was pending a BIOS update?
