http://www.realworldtech.com/forums/index.cfm?action=detail&PostNum=2588&Thread=1&entryID=36497&roomID=11
i need to change useur name.
I don't know, juin, Intel has never released speed bumps with Itanium. Itanium's current Madison lineup is the same as it was at Madison launch: 1.3, 1.4 and 1.5Ghz speeds... That's what makes me think that it's somewhat likely that 2.5Ghz speeds will be available in 2H05.2.5 is lot i think not sure thsi will be avaible at launch.
You assume, of course, that they did nothing to change that Xeon - I2 clock correspondence in hardware. However, they'd be wise to enhance 32-bit code execution... Even so, well, a Xeon MP with 24MB of cache and 10GB/s FSB would be nice at 2.5Ghz. And the other systemwide improvements will probably also make a difference in execution of 32-bit code.Itanium 32 bit perfomance is about equal to a Xeon MP of the same clock speed and teh same cache and bus.SO think about a XEON MP northwood with 24 L3 and 10 GB\S FSB.
Hm, a 10.6GB/s isn't three times the bandwidth, so I assume the memory controller has been greatly enhanced and has been made much, much more efficient. Bear in mind that 10.6GB/s is either Dual DDR2-667 (which will be out by then, and possibly with better-than-standard timings) or quad-channel DDR333. Intel has been using quad DDR200/266 for Itanium up until now. I wouldn't be too surprised if at some point they went dual DDR2-667, if they want to promote socket compatibilities for Xeon/Itanium... <wild speculation>I wonder if all of a sudden Itanium had an on-die memory controller? For dual DDR2-667 or quad DDR333? </wild speculation>Intel exec have say montecito will have 3 time the memory performance of Madison.The may sight of 256 bit bus or point to point.
That's for sure. IA64 with 24MB of cache, 2.5Ghz? I don't think even any IBM server-class processor will match that easily at all. I think it was P4Man who said that IBM's Power5 @ 1.9Ghz (current existing dual-core design) would not be outclassed by Montecito? Well, enter dual 2.5Ghz Itanium cores, and things ought to change a little...IMHO Nothing will even close to Montecito in major benchmark.SPEC FP rate will never be outclass except by tukwila.
The Madison 1.6Ghz, 3MB cache version is a dual-processor only and is not intended as a highest-end processor; the highest-end Madison is still the good old 1.5Ghz processor. A good indication of that is that the 1.5Ghz still stands quite solidly at its "ultra-high" price niche (~$4200), and the 1.6Ghz is cheaper.Yes madison 1.6GHZ 3MB is release and 1.7GHz 9MB should be release real soon question of few month.Montecito 2.5 GHZ maybe the max speed it can reach on low power consumation with a overall clock speed lower.I expect more something like 2.2 GHZ unless they want to go over 130 max power consumation.
No, it's not. If Itanium did a better job at generic 32-bit code, its acceptance might be speeded up considerably.Reply: why try to improve it it a big lose of time.
Hm, you're right here... it is conceivable that they're considering point-to-point busses. 6.4GB/s for two-cpu systems would be upgraded to twice 10.6GB/s, which is 21.2GB/s, which is, of course, around 3*6.4=19.2GB/s. Not bad.Reply: 3 time the bandwith is easy math.
for a while. When Itanium2 came out, it leapfrogged Power and x86, but meanwhile Power5 has convincingly regained the performance crown, and x86 has closed to gap considerably (not too say its in fact faster for quite a few things). I expect something similar to happen with Montecito, it may well be the fastest chip when it comes out, but it won't take long for x86/Power5+/6 to catch it again. Over and over, rince, repeat,.. heck, even Sparc64 is looking pretty damn impressive on paper these days. Also keep in mind a couple of percent performance is worth nothing in these markets (except HPC). No one will migrate to another architecture if performance or priceperformance isn't at least a factor 2 better. If not, Sparc wouldn't still be the best selling non x86 architecture out there.. So if you are a new kid on the block and want to capture marketshare from the established ISA's, you'd better be by far the fastest..You're right about that; servers often use only a few apps (heck, 1 or 2 quickly enough, and it's good enough), but I meant to increase Itanium's general attractiveness to the workstation and scientific community (of which I am part of)... This niche needs to constantly write or rewrite code... And is quite demanding in terms of floating-point performance!As for better x86 performance.. I'm not sure how crucial it is. For workstations it would be a considerable asset no doubt, but no one likes running critical non native code on a server, even regardless of performance. Servers also typically run a very limited ammount of apps, so either those are available natively, or you wouldn't consider the architecture for that app.
. Finally, for certain specific apps, Itanium may well be more cost effective already, in spite of the expensive platform..
