I have a theory that the greater the difference there is between the amount of air coming in and going out of a case, then the greater the noise will be over the standard noise the fan makes.
Take for example a car. When you drive down the road at a certain speed and open only the drivers side window, the air noise is at one level. It is usually fairly loud because the motion of the car is causing a sucking effect from the one window. Because there is on other window open, its very loud because nothing is being sucked. Its like turning on a vacuum and holding your hand over the hose.
Now, if you open the window directly behind it just a bit, the noise is greatly reduced. You can even fiddle with that second window to get the noise at its lowest point.
Now, transerring that example to PC cases. If I have 2 big fans in the back of the case sucking 100 cfm of air out, and only 50 or so cfm coming in, that same loud sucking sound could take place on a smaller scale. This would especially be noticeable on cases that are sealed VERY tightley so that air only comes in and out of the fan holes.
Also, if your fans sucking out are sucking more than is coming in, doesn't that cause the motor to strain and make a sound itself? That again is like a running vaccuum cleaner with something stuck in it so only some of the air is being sucked in. It strains the motor and causes more heat and sound.
Wouldn't it make sense to have the same or very close cfm going in as going out to reduce noise considerably?
I don't know, maybe I'm just being anal retentive.
