More PCI-E Cables for CX600M?
Adolfin
Commendable
Aug 31, 2016
27
I am attempting to fix a bricked GPU (MSI r9380 4gb) But to do this I need another card or integrated graphics to get into windows to Re flash the Vbios onto the card (It was bricked due to a failed flash). I do have another card but no integrated graphics, however my problem is is that my power supply (corsair CX600m) Only comes with 2 PCI-E power cables and I need 3. (The R9 380 requires 2 PCI-E 6 pins and the R7 250x requires 1 PCI-E 6 pin.) Is there a cable i can buy that goes from one of the Peripheral/Sata outputs to pci-e?
yes just look for dual molex to six pin adapter, but note this is not a long term fix, and with that power supply I would get it done as fast as possible. The CX series are not going to explode, but they are not great, so play carefully with them, reflash the card, and take out the R7 250X, done.
I am new to all these cables, where would the dual molex plug in? Also Yes when I'm done reflashing I was going to take out the old one
So I should get a molex to 6pin/pcie adapter, and plug in one of the molex cables from my psu peripheral slot? Seems to make sense.
The adapter should have two? Even if it only adapts to one pci-e?
Ah i see, could you link me to the right adapter?
Code:
Alright I understand, I will use them to unbrick my good GPU (hopefully) and then take them out as well as my other GPU. Thanks a ton!
Latest posts
