Lupiron Distinguished Feb 9, 2008 1,711 0 19,780 Mar 1, 2008 #1 Just checking to see what the optimal temps are for an Ultra before I move on to OCing them!! At a core clock of 680, mem 1132 and shader of 1596 I net 71c fully loaded. Dunno what the normal temps are, just asking as usual!! Thanks! --Lupi!
Evilonigiri Splendid Jun 8, 2007 4,381 0 22,780 Mar 1, 2008 #2 You are totally fine. Ultras usually idle around 60C and load is around 80C, but this all depends on case air flow and ambient temps. Just like how you're supposed to stay under 65C for cpu core temps, you should stay under 85C for gpu temps.
