Question More than one serial port on a Zero-W ?
Spinachy
163
I want to connect both an Adafruit GPS breakout (Adafruit ID: 746) and an Adafruit-sourced Lidar(Adafruit ID: 4010) to my Zero-W for a simple robot. They both use serial UART. Should I try a USB to Serial converter, or should I wire up something like a MAX3111 SPI to UART/RS232 converter chip?
USB adapters are OK, but you have to be careful on latency. I would think the LIDAR would be more important for low latency data I/O. The GPS data isn't going to change that much in a short period unless the GPS unit also has an inertial sensor or compass that you need for additional navigation input.
Reactions: bit_user
