T the one random guy Commendable Jul 23, 2016 25 0 1,530 Aug 31, 2016 #1 My friend is building a computer, and his motherboard has 1 3.0 and 2 2.0 ports and the case has 2 usb 3.0's at the front as is, so are some of the ports not going to work? or...? I am very confused.
Solution Gam3r01 Aug 31, 2016 Two 3.0 ports, or two 3.0 cables? If there are two ports they are both on a single cable, so they will both go to the same 3.0 header.
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Aug 31, 2016 Solution #2 Two 3.0 ports, or two 3.0 cables? If there are two ports they are both on a single cable, so they will both go to the same 3.0 header. Upvote 0 Downvote Solution
