[SOLVED] Most reliable compact case and motherboard for my specs?
Drew P
79
I’m trying to find a great space saving computer case while keeping the same components since next fall I’ll be moving into a dorm which as you know has very limited space. What is a great compact motherboard and case combo that fits the dimensions of my components? I’ve been loooking around but can’t make a decision. Also, side note, any low profile cpu coolers would be much appreciated if they are air. If not I’ll most likely end up going with water. Thanks! Hope it’s not too much to ask!
Parts list:
i7-8700k
EVGA GeForce GTX 1070 Ti FTW ULTRA SILENT GAMING
Corsair Vengeance 2x8gb RAM
EVGA 650W GQ 80+ Gold
P.s. I’m fine with getting a new power supply as well if needed if mine doesn’t fit the case or whatever other reasons. No need to research that though I can get that.
Small and compact, something like this...
CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor (Purchased For $0.00)
CPU Cooler: Noctua - NH-L9i 33.84 CFM CPU Cooler ($39.95 @ Amazon)
Motherboard: Gigabyte - Z390 I AORUS PRO WIFI Mini ITX LGA1151 Motherboard ($157.35 @ Amazon)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory (Purchased For $0.00)
Video Card: EVGA - GeForce GTX 1070 Ti 8 GB FTW ULTRA SILENT GAMING Video Card (Purchased For $0.00)
Case: Thermaltake - Core X1 Mini ITX Tower Case ($99.99 @ Amazon)
Power Supply: EVGA - 650 W 80+ Gold Certified Semi-Modular ATX Power Supply (Purchased For $0.00)
Total: $297.29
Generated by PCPartPicker 2019-04-06 21:50 EDT-0400
Total: $297.29
This is great! Thank you so much!
