Sorry for using the same thread. It's just that all my other forum subscriptions strongly encourage me to search for the problem and in case I find it anywhere, they compell me to continue my story there. My bad.
Ok, so the connector itself provides the necessary power, but maybe -just maybe- the power isn't necessarily sustained. This I can understand from your words.
Should I be worried in long term usage (as in prolonged uptime - which is not the case) or even in short usages, about 2-3 hours of intensive gaming could harm the board somehow ?
For starters, I'm not into the overclocking business. I've already spent a lot of anger resources just making the bloody thing work at full speed. It took me about a week, but using PMT it really uses that multiplier correctly.
Second of all, the board manual (ASUS M2N32 SLi Deluxe) states in multiple instances that (9 year old) innovations like "
6 phase power design" and "
cool vrm heatsink design" is really up to the challenge of heavy processing power. Now I realize they weren't reffering to Phenom IIs, but I believe they weren't that far of the thruth either.
What CAN I tell for now is that I've been extensively using testbenchs like Mersenne Prime 95, 3D Marks and AIDA's own stress test and it really provides a cool, unexpectedly stable operation. I can even monitor the voltage provided to the CPU (and several other components) and I must say it's a heavy solid straight 1.35V line; for hours and hours.
Looks like the electronics inside the TX series really stands out and earns it's money.
What I can also expect though, for the worse, is the breaking of the cheap looking capacitors... I mean my jaw dropped when I saw those things mounted on the mobo when I bought it ; for a flagship product that was so expensive, not using japanese quality really was a downside.
Anyways, today I've bought myself a GTX 770 and in addition to this Phenom CPU it really REALLY makes this old rig play the latest games with enormous ease. It's like my rig has been reborn, and after almost 10 years it can actually keep pace with nowadays trends.
I'm rather satisfied with how things are evolving regarding my configuration and, since the purchases are done, hope only for the best.
I managed to get hold on a Gigabyte Ultra Durable AM2+ mobo with an EPS connector just in case this one breaks down.
Thank you for your very comprehensive answer. I owe you one.
Best wishes.
blazorthon :
We would have preferred that you open a new thread, but alright.
Short answer: That is a risk (for the board, not the connector), but nothing is guaranteed.
The 4-pin power connector is plenty for a 125W chip. That connector is rated for 144W and that includes a safety factor since the 18 gauge wires and connector are physically capable of considerably more. The only concern I'd have with using a CPU that is over the recommended wattage of the board is with the power regulators on the board. The board wasn't necessarily made to handle the extra power and it can misbehave as a result. Sometimes that causes early failure of the board because it's delivering more power than it can safely handle for too long. Sometimes the board doesn't deliver the full power that the CPU wants instead and that can lower performance and/or cause system instability.
The Phenom II CPus that have 125W TDPs might actually use more power than the Phenom II CPUs with the same 125W TDP. Keep in mind that TDP and power consumption are not perfectly related and the way TDP is rated can be different between different generations.
Also keep in mind that for each model number, there are sometimes multiple models- a regular (locked) CPU and a Black Edition (multiplier unlocked). The board might be rated for the regular models (which are mostly 95W for Phenom and Phenom II), but not for the 125W Black Editions with the same model numbers.
Nitpicking: The 4 pin CPU power connector is not an EPS connector. The EPS connector is the 8 pin connector, which is rated for twice the power (288W). The 4 pin connector is sometimes called the P4 connector.
