Motherboard and Case compatibility issue.
Chubsmagee
26
Hello, I recently put together this build: http://pcpartpicker.com/user/Chubsmagee/saved/4kQG3C. At the bottom it states that "ASRock H97 PRO4 ATX LGA1150 Motherboard has an onboard USB 3.0 header, but the Rosewill CHALLENGER ATX Mid Tower Case does not have front panel USB 3.0 ports." Could I fix this issue by getting the USB 3.0 version of the case?
Thanks.
It is not really a compatibility issue as your motherboard has support for a 2.0 USB as well. But yes if you upgrade your case to a USB 3.0 then you will be able to use the 3.0 header on your board.
Unless you require USB 3.0 on the front of your PC it really doesn't matter.
