Motherboard and case question
The Silence
28
Hi,
This question isnt terribly difficult, its more like a double check, im purchasing a EVGA X58 triple SLI motherboard that has 6 slots on it. I want to get a coolermaster HAF 932 that has 7 slots for the motherboard, will I have any problems when im going to install it? Like is the motherboard going to be off with the fittings in the case
Thanks,
The Silence
Motherboard:
http://www.evga.com/products/moreInfo.asp?pn=132-BL-E758-A1&family=Motherboard%20Family&series=Intel%20X58%20Series%20Family
Case:
http://www.coolermaster-usa.com/product.php?category_id=18&product_id=2810
ionut19
961
38
No, the motherboard will be fine. Even if you have 10 slots it will be ok because there is a standard for all and the extra slot or slots will just be underneath your motherboard. Go for them.
Similar threads
