motherboard and case replacement
caremal5
146
Hi there, I'm looking to replace my asus p8h77-i for just a regular sized motherboard and also my current case to something a bit taller and less wide. I don't mind spending around £70-£80 on the motherboard and £20-£30 on the case. Also will I be needing a new power supply for this? my current one is a sst strider 400w psu.
Hi, I took a look at the case and it seems that it's not available in the uk, and I don't want to have to pay extra delivery costs. If you could find me one available in this country it'd be appreciated.
Sorry lol, I forgot about the pound sign.
Motherboard: Asus P8Z77-V LX ATX LGA1155 Motherboard (£68.42 @ Misco UK)
Case: Thermaltake Versa H22 ATX Mid Tower Case (£26.87 @ Ebuyer)
Total: £95.29
Generated by PCPartPicker 2015-06-15 02:06 BST+0100
Honestly, I don't think you'd need a new Mobo. It's up to you though
This one's too small and doesn't have enough ports for all of the wires so I'm stuck with a pc that doesn't have half the usb's working and ended up needing an audio adapter even though this was a a "pc gamer rig" from pc gamer magazine. Very poor design on their part.
Hi again, only just had a look at the mb you suggested and it's either impossible to find or when I do it's on a dodgy site with terrible reviews or way overpriced. Could you please recommend me one which is easy to find and relatively cheap (£80-£100) on either newegg, ebuyer or amazon? Also will my SILENX EFZ-100HA2 CPU Cooler fit on a normal sized cpu?
