Motherboard and Case
That is a standard ATX motherboard any midtower will work.
The case will tell you what motherboard will work.
Example.
https://www.newegg.com/Product/Product.aspx?Item=N82E16811854068&ignorebbr=1&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Cases+%28Computer+Cases+-+ATX+Form%29-_-N82E16811854068&gclid=EAIaIQobChMItJHJ74_l2gIVDBWBCh0NhgnHEAQYASABEgIljPD_BwE&gclsrc=aw.ds
Under the specks you will see this.
Motherboard Compatibility
Micro ATX / ATX / Mini ITX / E-ATX (E-ATX* - up to 275 mm wide
Example.
