Motherboard and CPU Issue
WheezyXD
I have a Pre built system which I started upgrading back in February of this year recently I upgraded the CPU and now one of the DIMM slots won't work.
Before the Upgrade the DIMM slot worked perfectly. Now it doesn't work I went back and checked everything like if there was debris in the RAM slot if the motherboard pins were broken if the RAM was broken but all of these where ruled out and they weren't the problem.
Could it be the memory controller on the CPU that's messed up. I brought the CPU which is an I7 for £107.50 with 12 months warranty.
There's always a solution, you just can't test to find out what it really is. You can try to send back the cpu since it has a warranty, they'll test it.
So there is no solution for the CPU and motherboard then???
Yeah I ended up sending it back got a refund and ordered another one it turned out to be the memory controller on the CPU that was malfunctioning.
