Motherboard and CPU overheating up to 100C degrees
ZiegBitingDog
Commendable
Apr 8, 2016
For some reason I'm having a real bad overheating problems since a month or so. The only way to fix it is cap my CPU power at 70%, my motherboard temperature drops same time as CPU. I have used different programs to check my temps, Open Hardware Monitor, Speccy, HWmonitor and else stuff but all showing me the same problem, I have to admit it's started since I bought a new CPU(thermal paste set just fine), My old one was AMD Athlon X2 250 and current is AMD Phenom II x4 955 and as fast as I installed it I'm having troubles with overheat, could it be that my Motherboard(ASUS M3N78-VM(AM2)) is not up to date?
tothergnome
Respectable
Mar 27, 2016
413
138
PCPartPicker part list: http://pcpartpicker.com/p/KxTHxr
Price breakdown by merchant: http://pcpartpicker.com/p/KxTHxr/by_merchant/
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($159.89 @ OutletPC)
Motherboard: Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard ($54.88 @ OutletPC)
Total: $214.77
Generated by PCPartPicker 2016-04-08 09:15 EDT-0400
Spend 200 dollars as its a good investment were you won't have to overclock. As well as the competents being outdated.
Similar threads
