Motherboard and gpu light on nothing else works
scotter13
4
Motherboard (gigabyte Z170x Gaming 7)and gpu is on but fans wont turn on cpu cooler ,case fan or gpu.
Any help is much appreciated.
intel i5-6500 3.2 ghz quad core processor
Gigabyte-GA-Z170X-Gaming 7 ATX
asus-GeForce GTX 1060 6gb Dual Video Card
16 GB G-Skill Ripjaws DDR4
EVGA-superNOVA G3 650W
You don't need to.
If you unplug the Power supply.
And use the jumper on the MB to reset it, you can also just remove the battery for a few mins.
Then plug it back in and turn it on.
Location of the jumper is in your MB manual.
