Hello,
This is the first time I am building a computer from scratch andI need some advice on purchasing a motherboard and power supply. I have bought an i7-3930K and 2 GTX 690s (well one I got as a gift), but I am not sure which Asus X79 motherboard to buy (as there are many different versions), also I hear you need a power supply with over 1000W if you have 2 GPUs. Please advise. Thanks in advance!
Never have looked at these, in depth, anyway, as they are out-of-this-world expensive. I don't have that kind of cash.
) that I will not be using the computer I am building for any gaming whatsoever. I will be using it as a workstation for high performance computations on CPU and GPU (using CUDA). I have adopted this approach because the performance/cost of extreme gaming components are much higher than components designed for workstations for example , i7-3930K is 1/3 the cost of a Xeon E5-2670 but the latter is only 20% faster and the GTX 690 is almost 1/4 the price of Tesla K20 but the latter is only 50% faster.
