Motherboard: https://altex.ro/placa-de-baza-asrock-b360m-pro4-socket-1151-4xddr4-6xsata3-matx/
RAM: well not much choice at this site, this https://altex.ro/memorie-desktop-kingston-hyperx-fury-16gb-ddr4-2666mhz-cl16-hx426c16fb2k2-16/ if you can afford 16 Gb, if you can't then there is a problem as the only available 8 Gb kits are 3000 MHz, so you would be paying for speed you won't use anyway (2400 is max for that CPU/motherboard combination).
