Question Motherboard Audio Jack Not Working
The Hero of Orlais
Commendable
Jun 26, 2017
144
Its not working there, it was working just fine a night before, but I think someone use my PC and I noticed they change my earphone jack so it connected to the case jack, instead on the motherboard jack, but when I plug it into the motherboard jack, there's no sound coming out, but its working fine with my case jack(well the audio quality get downgraded pretty bad), any idea how to fix it? thanks.
The Hero of Orlais
Commendable
Jun 26, 2017
144
In your audio settings (the audio icon on the taskbar), there should be a dropdown for which device is your 'speaker'. Might be as simple as changing that.
Oh wow, I don't know what happens, but when I try to use your solution, and when I plug my jack to my ,otherboard, it just work, no need to do anything, thanks anyway though
