Motherboard Audio Question
ZeroGravity780
782
I have the gigabyte z87x-d3h motherboard and i was wondering if i could put a better audio card in it or whatever. I dont know anything about audio on motherboards so your help is appreciated.
Well, a sound card will definitely sound better when you compare analog outs (which is the green jacks). A sound card wont affect the sound the headphones make, since it uses its own sound card built in to the headphones.
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132053
This card sounds great out of the green jacks. It also has DTS connect which you can hook up to a receiver with 1 single optical cable, and it will make your games output in real 7.1.
