Question motherboard audio
Jul 27, 2020
9
when i connect my headphone to my motherboard the USB I/O ports. There is audio coming out but when i adjust the volume level from 100 to 0. The sound level stays the same until it hits 0 which will switch off. it doesnt go softer like from 100 to 0. anyone know how to fix this?
motherboard: asrock b450m pro4
cpu: ryzen 5 3600
ram: teamgroup TUF 16gb 3200mhz
GPU: zotac rtx 2060 OC
ssd: lexar nm610 500gb
hdd: seagate 1tb
Lutfij
So you can't get a transition from high to low...?
Headphone's make and model? If the headset is USB driven then you might need to;
a| Make sure you're on the latest BIOS update for your motherboard
b| Make sure your chipset drivers are up to date, might want to reinstall them.
c| uninstall the USB driven audio card in Device Manager and reboot the system.
For added measure, include the make and model of the PSU.
dudio
2,292
14
12,965
466
Does the headset have its own in-line volume control ? It may be that the headset tries to maintain its in-line volume setting regardless of the Windows setting, up until the point there is no signal.
What headset?
