YOUR HELP MEANS A LOT TO ME PLEASE HELP.
READ THIS FIRST THANKS .
(ALL WORKS FINE , THE GPU , THE CPU , THE MONITOR , THE PSU,THE BIOS BEFORE I DID THIS )
Hey guys , to start with i was trying to install an os or reinstallin windows 10 via bootable flash drive because it has problem in fresh install .
So when i go to the set up windows 10 , i was in settings where you can format and delete disk or files . I did was delete all and only left is unllocated disk , the windows 10 reinstall toturial said that justmake it like that , so i click next but it says you (cant create partition) something like that maybe thas not the exact word . So i was searching for some help , it says there that go exit the installation ang go windows advance settings where you can touble shoot and go to cmd to change something, so ofcourse i turn off my computer and remove the flash drive enable to get there (i have a previous 10 windows installed already ) but when i turn on it just go to a blank bios , it has logo bios but the settings like ,(press f12 or press del buttons) are not there and reboot again and its keep happening . So I'm searching agian what to do and they said remove the cmos battery make sure unplugged the power cord I( Did that) and also some says remove the cmos pin is the best way to reset it but (mymobo dont have it cmos pins )(gigabyte Ga-970a-ds3p rev.2) .What i did was turn off my conputer , power cord unplugged turn off psu switch removr cmos batterry and leave for like 15 mins and reinstall again like before .Also i tried different ram slot (One ram stick) .After i did that I turn on my pc like before , the leds , the cpu , the video card is working like before.The only thing is different is the mouse , monitor and keyboards led is not turning on (cant even go to bios ). And also it just blank screen , to turn it off i need to hold the power button like (5 sec just like before) not (1 sec)
And all i see is black screen . I even remove and reinstall the (GPU) its the same 🙁. All black . Or no display.
What should i do guys I really need your help 🙁..
I Need My PC Working for educational porpuses . Can help my education or my future too
HELP.
THANKS IN ADVANCE
HELP.
THANKS IN ADVANCE
