Motherboard choice Help
Zeludon
44
Im building a pc soon (http://au.pcpartpicker.com/p/tK9svK)
And I canot chose a motherboard between the MSI H97 Gaming 3, Gigabyte H97 Gaming 3 and the ASRock Fatal1ty H97 Performance,
im looking for a red/black board if you have other suggestions and it has to be ATX form factor.
Feel free to critic other aspects of my build.
Go with 8.1.
Windows 8.1 will also receive Direct X updates.
With windows 7 OEM the license is tied to the first motherboard it's installed on.With Windows 8.1 you can move it to another build when you are done with this one , but only one computer at a time.With Windows 8.1 you can change all the hardware you want including the motherboard.
OEM versions of Windows 7 are identical to Full License Retail versions except for the following:
- OEM versions do not offer any free Microsoft direct support from Microsoft support personnel
- OEM licenses are tied to the very first computer you install and activate it on
He means the ASRock Fatal1ty is his choice.
Personally, I'd go for the Gigabyte. ASrock had a bit of a bad history, though they're coming back. All in all, I'd go for the one with the best specs. I.e., most PCI-e x16 lanes, max memory, most SATAIII/Sata 6Gb ports, etc.
Go with 8.1.
- OEM versions allow all hardware upgrades except for an upgrade to a different model motherboard
- OEM versions cannot be used to directly upgrade from an older Windows operating system
Microsoft.com ^
OEM vs. Retail
OEM Windows 7 comes preinstalled on computers. This is the cheapest way to buy windows. Large PC manufacturers like Dell, HP etc. (collectively called royalty OEMs) install windows on millions of such PCs. The main characteristics of such systems are:
The license agreement and support agreement is between you and the PC makes.
Activation by the end user is not required. Windows is preactivated at the factory by the OEM using images and standard SLP keys.
Your copy of windows is locked to that PC. The license is not transferable.
OEM system builder is what you get when you buy from say Newegg or from a local "white box" vendor. It too has the characteristics of Royalty OEM windows. Although it is possible for an individual to buy a System Builder copy, the license requires that the software be installed using the OPK (OEM preinstall kit) and then resold.
Retail version is what you buy from a retailer like Amazon or Bestbuy. Its a full price version that comes packaged in a retail box with a retail product key. It has to be activated online via MS servers using the key on the box, it is not tied to the PC it was first installed on, though it can only be used on a single computer at a time. And, MS directly provides the support for it. It is also more expensive than OEM copies.
As far as functionality is concerned, theres no difference between any of the versions above, given any specific edition (i.e. between OEM pro and retail pro, or between OEM ultimate and retail ultimate).
sevenforums.com
Windows 8 is a whole different ballgame.
License agreement for the transfer of a Windows 8 license
http://personaluselicense.windows.com/en-US/default.aspx
