Motherboard Choice Help!
RomitchGaming
25
Greetings everyone! I need some help. I have ordered and received the following parts.
http://pcpartpicker.com/p/TPnHwP
I can't seem to find a compatible motherboard! The entire list is empty, and I've already reordered and sent back 2 items already! I want this his motherboard that I'm sending back to be the 3rd and FINAL thing I send back! Can you guys please help?
Here is the current incompatible part list that I have.
http://pcpartpicker.com/p/Rgtg23
Incompatibly Notes:
Intel Core i5-4690K 3.5GHz Quad-Core Processor and Gigabyte GA-H170M-DS3H Micro ATX LGA1151 Motherboard are not compatible.
I need a gaming motherboard that Is comp. with the Intel Core i5-4690K 3.5GHz Quad-Core Processor, The Crucial DDR4 Memory that I ordered, The EVGA GTX 960 SuperSC Acx 2.0+ that I ordered, etc. etc. (And fit in my 200r Case!)
Any and all help is very appreciated. Excuse my noob-ness for missing the compatibility issues! ;_; 🙁
I had the same experience myself with your config. I did go to the Description of your Proc and on the left-hand side of the window, scroll down to 'Compatible Parts' and select the link View Compatible Motherboards. It will show all M/B, for your Proc. It could be one of your items you selected already is not compatible with the motherboard generation. Start over with Proc, then M/B, then RAM. Should allow you to select a nice system.
Thanks so much! Will do!
