D dalll Reputable May 3, 2014 22 0 4,510 May 8, 2014 #1 I want to know if my MSI FM2-A85XA-G43 will be compatible with a xigmatek recon case
Solution Phillip Corcoran May 8, 2014 The MSI FM2-A85XA-G43 is an ATX form factor board. The Xigmatek Recon case accepts ATX, MicroATX, and Mini-ITX boards as clearly stated on the Xigmatek product page: http://www.xigmatek.com/product.php?productid=215&type=specification The board will indeed fit.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,104 912 120,140 May 8, 2014 Solution #2 The MSI FM2-A85XA-G43 is an ATX form factor board. The Xigmatek Recon case accepts ATX, MicroATX, and Mini-ITX boards as clearly stated on the Xigmatek product page: http://www.xigmatek.com/product.php?productid=215&type=specification The board will indeed fit. Upvote 0 Downvote Solution
