B BigDawhg Jan 10, 2020 13 0 10 Jan 11, 2020 #1 are all IO panels compatible with all motherboards? Last edited: Jan 11, 2020
Newtonius Honorable Sep 25, 2019 1,797 441 9,590 Jan 11, 2020 #2 No, some motherboards may share the same design and layout of the IO but this is not commonly the case. You will need the IO shield designed for the motherboard for it to fit. YOu can always try it out first but it will most likely not fit. Upvote 0 Downvote
