Motherboard compatible CPU upgrade recommendations?
fredfred5150
15
Hello, I'm a tech dummy I want to upgrade my processor soon, I do cpu based rendering (no gaming) so I need raw computational power, but I'm not sure how to know which CPU's are compatible. According to a program called Speccy here are some component details of my PC
Motherboard
Manufacturer: Hewlett-Packard
Model: 2AF7
Version: 1.0
Chipset Vendor: Intel
Chipset Model: Haswell
Chipset Revision: 06
Southbridge Vendor: Intel
Southbridge Model: H87
Southbridge Revision C2
CPU
Intel Core i3
Codename: Haswell
Package: Socket 1150 LGA
I was told by a few people that compatibility is based on socket type, based on that (and what I can afford) I was looking at an Intel Core i5 -3570K or an Intel Core i7 - 4470K.
Am I right in thinking one of the above is compatible?
If so, and I upgrade, will I need to upgrade any other components to handle the new cpu? (like a cooling fan?)
Basically what do I need to know?
Hello... here is General chart of CPU performance... http://www.cpubenchmark.net/common_cpus.html
A "K" version chip is Unlocked for MB/Bios higher speed tweeking... But your MB is not a "Z" version, so you cant use that feature...
Your MB is a a Socket 1150 and requires a matching 4th gen CPU... The Core i5 -3570K is a 3rd Gen and a 1155, will not work.
i7 is a quad core w/HT
i5 is a quad core
i3 is a dual core w/HT
if your Software supports Hyper Threading, it will have Eight cores of power with the i7.
Is this a laptop? If so you would need to confirm that you can remove it and then find a compatible laptop CPU for your motherboard. You may want to think about getting a new more powerful laptop if that is the case.
If this is a desktop then the people above have pretty much summed it up for you.
Socket 1150 is desktop. Do you have the model number for your HP? I believe a 4770 will be compatible.
My PC is a desktop: Pavillion 500-123ea (running windows 8) , the rendering software I use supports Hyper-threading, I have no interest in overclocking or otherwise tampering with internal workings/settings, I simply need more CPU threads/speed/power/whatever the correct term is to reduce rendertimes.
If I understand the replies so far basically this is what I go for? http://www.amazon.co.uk/Intel-Graphics-BX80646I74770-Generation-Technology/dp/B00CLD9URS
Also, in terms of going inside a pc, I've only ever installed a graphics card, bearing that in mind is fitting a new CPU something I could do? Is it idiot proof or should I pay someone to do it for me?
Installing a new CPU is not idiot proof, but you can do it. The key is to be methodical and not rush it, no reason to spend 200 pounds and waste it by not taking your time during the install. Before you start have a clear work area on a table for your computer chassis and make sure your hands are clean.
First of all shutdown and unplug the machine. Then set the machine on your work surface next to your CPU box (There is no reason to open the CPU box before the install, that just increases the chance of scratching or getting dirt on your CPU). Static electricity is the next thing to consider. You can either wear one of those static bracelets, which can be had rather cheaply, or make sure to touch the outside of the computer case periodically during installation to disperse any static charge (Your computer needs to be metal for the second method to work). Next open your computer case as per instructions from the manufacturer. I know most people read the directions if all else fails, but it can save time or headache if something isn't quite intuitive. If you don't have a hardcopy manual most manufacturers have them in .pdf format on their webpages. Once your machine is open and you're looking at the CPU follow these instructions from Intel. Note the final instructions for installing the thumbscrew heatsink fan because you'll need to do them in reverse to take off the original heatsink fan. http://www.intel.com/support/processors/sb/CS-032258.htm
-Dylan
Thanks for the answers, really cleared things up, one thing remains though, if I buy the retail/boxed version, is the thermal paste pre-applied, or will I have to order that as well, and apply myself?
Not laziness on my part, just that fewer steps equals fewer opportunities for something to go wrong.
You can still do mild overclocking with the non-K versions.
Not on an HP
Nor with Haswell. Intel removed that ability with Haswell.
What (if anything) do I clip the anti-static wristband to?
I installed my new cpu...but the pc wouldn't start the first few times I tried, I'm running windows 8, but windows "View basic information about your computer" still thinks an i3 is the cpu however a program call Speccy reads the i7 being the cpu, but it says I have 2 cores and 4 threads, I should now have double that amount
Core temp is hovering around 32 degrees, but I haven't tried rendering yet (temp will go up)
Should I be worried about anything or did I install the cpu correctly?
Looks like your BIOS doesn't recognize the CPU since it's brand-new. Should've gotten the 4770, since you're dealing with an HP. As long as you see 8 graphs under performance in Task Manager, you should be all right. You might try fiddling in the BIOS to get it to recognize it correctly.
downloaded and installed BIOS update, Windows now showing correct CPU, only one graph under performance in Task Manager (but does say I have 4 cores and logical processors), Resource Monitor has 8 CPU graphs, temperatures hovering around 27 degrees.
So considering I've never done this before, can I relax now? Have I installed this correctly?
Sounds right - I'm not familiar with the Win8 Task Manager I guess, but I think you can get it to show each logical core.
