samrockp3 Honorable Apr 27, 2015 140 1 10,695 Oct 26, 2015 #1 Looking for a $230 cpu and motherboard combo for gaming.
oddaaron00 Reputable Jul 16, 2015 178 0 4,710 Oct 26, 2015 #2 Any preferences? Motherboard size, estimated PC specifications (GPUs, etc)? Upvote 0 Downvote
samrockp3 Honorable Apr 27, 2015 140 1 10,695 Oct 26, 2015 #3 ill probably put an r9 270x or 280x in. I also have a full tower case so that answers your mobo size question Upvote 0 Downvote
Hawkshot Admirable Aug 19, 2014 1,772 0 6,460 Oct 26, 2015 Solution #4 I would get you to try this http://uk.pcpartpicker.com/p/6hFnqs Upvote 0 Downvote Solution
ChumP Splendid Sep 16, 2014 3,408 286 28,390 Oct 26, 2015 #5 A little bit over your budget, but it should be great for gaming. You need a Mid-Tower or bigger case for the given motherboard. CPU : Intel Core I5-4460 - $173.89 Motherboard : ASRock H97 Anniversary - $64.99 Total : $238.88 Upvote 0 Downvote
samrockp3 Honorable Apr 27, 2015 140 1 10,695 Oct 26, 2015 #6 Hawkshot : I would get you to try this http://uk.pcpartpicker.com/p/6hFnqs This is what im gonna go with http://pcpartpicker.com/p/JqRKmG its based off of your response, thanks Upvote 0 Downvote
samrockp3 Honorable Apr 27, 2015 140 1 10,695 Oct 26, 2015 #7 Hawkshot : I would get you to try this http://uk.pcpartpicker.com/p/6hFnqs This is what im gonna go with http://pcpartpicker.com/p/JqRKmG its based off of your response, thanks Upvote 0 Downvote
Hawkshot Admirable Aug 19, 2014 1,772 0 6,460 Oct 26, 2015 #9 Awesome glad I could help hope all goes well! Upvote 0 Downvote
