Question Motherboard Debug LED on VGA all of a sudden
raywestnit
21
Hello! I would like to ask for some assistance regarding what happened to my system out of nowhere, it was fine last night but when I tried opening the system it showed a VGA debug LED on the motherboard all of a sudden.
Quick troubleshooting I did
-Re seat the graphics card
-Clear CMOS
-Clean the pins on the gpu with an eraser
-Removed GPU and tried to see if the LED debug would still light it (It did)
I don't have a spare GPU to test if it is, but I'll have a buddy over to do some more trouble shooting just wanted to ask if you guys have any suggestions or tips on what to do or if you've experienced something similar and found a fix.
I'm honestly hoping its not my graphics card dying out of the blue, I just upgraded my monitor and won't have anything to replace it right now if it did die.
System specs:
Ryzen 5 5600
RTX 2060
Crucial Ballistix 16GB 8x2 3200 Mhz
Seasonic 620w modular PSU
Teamgroup 256 GB M.2 SSD
WD Blue 1TB HDD
Is this the S12II or the M12II? How old is the PSU in question? In either case, that's not a PSU that you should be running with the above listed specs.
You've posted this thread in the Motherboard's section but you forgot to mention the make and model of your motherboard. You should also add the BIOS version for your motherboard.
Oh it is the seasonic m12ii evo 620w, now that I look at the results online it looks bad lmao, it's a couple of years old by now maybe like 4+ years?
could be a faulty psu then?
and yes I forgot to add the motherboard its the MSI B450m Mortar max I'd check the bios version but I can't check it atm.
-One stick of ram on different slots
-Clear CMOS
System specs:
Ryzen 5 5600
MSI B450m Mortar Max
RTX 2060
WD Blue 1TB HDD
