Motherboard died, need recommendation for replacement
GTX560
36
GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD
That is the motherboard,
the rest of the system is
Asus 24xDVD-RW Serial ATA Internal OEM Drive DRW-24B1ST (Black)
Western Digital Caviar Blue 500 GB SATA III 7200 RPM 16 MB Cache Bulk/OEM
Thermaltake V3 Black Edition VL80001W2Z No PS Mid Tower Gaming Case (Black)
Thermaltake Power Supply 240-Pin 800 Power Supply TR-800P
AMD FX-8120 8-Core Black Edition Processor Socket AM3+
Corsair Vengeance 8 GB ( 2 x 4 GB ) DDR3 1600 MHz (PC3 12800) 240-Pin DDR3 Memory Kit for Intel Core i3, i5, i7 and AMD Platforms SDRAM
I would like to use all the component and just replace the motherboard.
Thanks for help
How did you manage to kill that MB ? My is still running strong with FX 8350 at 4.8GHz. It can handle GT 1060 just as fine as any other. Are you sure it's MB that's bad ? I don't think anybody is making AM3+ MBs any more and that one was one of best ones.
One thing I could mention, originally this system was built for the GTX560 graphics card. Then I upgraded to the GTX1060. Is there a chance that that older style of motherboard cannot handle the 1060?
As in my other option is to go with an updated new motherboard AMD Ryzen 7 and new ram which will run quite much (for me) up to around $400.
That would be an improvement in performance. Is it worth it?
