Motherboard does not have Power Fan Connector! Help!
Barnito10
42
I bought the ASRock H97M Anniversary motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157547
but now that I'm installing it I noticed that it does not have a power fan connector on the board. So now I won't be able to use that fan. What should I do? Should i just return it?
I was using this board before
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157483
I have the Rosewill FBM-01 case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147123
Please help me guys
You can connect one of the fans to the power supply, by using a molex to 3/4 pin adapter. The fan would run at full speed in this case.
SR-71 The thing is my case has two addition fans. So i would only be able to use one and the CPU fan. Would you recommend for me to keep it like that?
Alexoiu
Could you please explain how that would work? if the fan is running at full speed would that be loud? I never mess with the fan speeds i don't even know how.
But how would i install that cable
thanks
