Motherboard doesn't come with enough fan headers
ComputerTech101
Commendable
Aug 8, 2016
31
I just received all my parts and started building only to realize I don't have enough case fan ports. This is my first time building a PC so I don't know what to do. All my case fans are 3 Pin
SilverStone PWM Fan Hub System Cables, Black (CPF04)
https://www.amazon.com/SilverStone-System-Cables-Black-CPF04/dp/B00VNW556I/ref=sr_1_1?ie=UTF8&qid=1471729285&sr=8-1&keywords=silverstone+hub
I use these fan hubs , very small , work great.
http://silverstonetek.com/product.php?pid=526&area=en
Look here.​
Connect the fans to the SATA power cable, or the Molex power cable plugged into the PSU - "Daisy chain" them if necessary.
how do I do that?
Look here.​
could I control the fan speed if the fans are plugged into this?
Is it compatible with 3 pin fans?
3 pins a work on a 4 pin connector yes but your motherboard connection must be a 4 pin. And then all the fans must be the same 3 pin. if you mix 3 and 4 pin fans the motherboard must have support of and be able to identify each type which most do not. 3pin pwn use a different voltages to differentiate certain pre-set speeds whereas a 4 pin has more control over speeds because it can adjust speed by rotation on the fly without adjusting the voltage. hope that helps.
All my motherboard System fan headers are 4 pin. all of my fans are 3 pin. Im guessing it will work?
also here is my motherboard:
Gigabyte GA-Z97X-UD3H ATX LGA1150
Latest posts
