Motherboard doesn't have enough fan headers , please help
TheErolley
15
Hello , so i bought a new PC and apparently the motherboard has only 3 fan headers , i use 2 for my Noctua NH D14 so only one left , the problem is i bought 5 fans and i only have one headers , what do i do ?? i really want to use all of my 5 fans and i don't want to have to buy a new motherboard , i heard i can plug my fans in my PSU but i am not sure , i am going to link my motherboard my fans and also my PSU please help me and tell me what adapters i should get and where to plug the fans because i don't have enough experience in PC building at all
PSU :https://www.amazon.com/EVGA-SuperNOVA-Crossfire-Warranty-220-G2-0750-XR/dp/B00IKDETOW/ref=sr_1_1?s=pc&ie=UTF8&qid=1469892916&sr=1-1&keywords=EVGA+SuperNOVA+750+G2+80%2B+GOLD
Motherboard :https://www.amazon.com/ASUS-Z170-P-ATX-DDR4-Motherboards/dp/B012VOO3E6/ref=sr_1_1?s=pc&ie=UTF8&qid=1469892930&sr=1-1&keywords=z170-p
Fans : https://www.amazon.com/Corsair-SP120-Quiet-Twin-Pack/dp/B007RESFR2/ref=sr_1_1?s=pc&ie=UTF8&qid=1469892881&sr=1-1&keywords=Corsair+Air+Series+SP120+Quiet+Edition
Thank you for the quick answer but if i used the SilverStone fan controller would they run at full speed ? also do i plug the fan controller to the PSU or the Motherboard ?
Thank you very much , i was really worried about having to buy a new motherboard
You will be able to connect the hub to the motherboard, but I'm not sure if it will be able to control the fans speed (not running at full speed). I'd say that it should work, but the users reviews are contradictory. Some say it doesn't work, some say that it does.
