Hi,
I want to build a PC and for the motherboard I decided I would get the MSI H110M pro D - which has only one Fan Header - that seemed alright when I decided which MOBO to get.
However, after some readings about this I realised I would like to have all my fans PWM controller and not just connect them to the PSU to run at max speed.
I already have a i5-6402p CPU and a Corsair CX550M and for GPU I intend to go with a Asus GTX 950 or a Sapphire RX 460.
I would like to get a NZXT S340 or a phanteks p400 case - both which have 2 fans included.
Would those 2x120mm fans be enough for my rig? I thought I could get a splitter and connect them both to the motherboard? Would that be safe/reliable? Should I try to spend more money for a 2 Fan Header MOBO or maybe get a PWM fan controller such as (Phanteks PH-PWHUB_01)?
I'm a bit confused about this and I just want to make sure I'll have enough airflow and control.
Thanks!
Thanks!
