C CoolGamerFrost Distinguished Aug 28, 2014 72 0 18,630 Sep 2, 2014 #1 Hi will the best value pulse 700w 120mm 3pin PSU fit in the sabertooth 990fx along with the corsair air series af120 fans?
Solution legend001523 Sep 2, 2014 hmm... If you can afford it get the second link i posted, both will provide sufficient power even with a 760
legend001523 Splendid Jun 3, 2014 7,394 0 29,960 Sep 2, 2014 #2 yeah the wattgae is fine but never heard of that psu, get a better one maybe Upvote 1 Downvote
C CoolGamerFrost Distinguished Aug 28, 2014 72 0 18,630 Sep 2, 2014 #3 Could you recommend one not too expensive though Upvote 0 Downvote
legend001523 Splendid Jun 3, 2014 7,394 0 29,960 Sep 2, 2014 #4 CURRENCY ND WHERE DO YOU LIVE? sry caps lock Upvote 1 Downvote
C CoolGamerFrost Distinguished Aug 28, 2014 72 0 18,630 Sep 2, 2014 #5 It OK and £ uk Upvote 0 Downvote
legend001523 Splendid Jun 3, 2014 7,394 0 29,960 Sep 2, 2014 #6 ^ was raging on lol so forgot that I still had caps lock 😛 http://www.amazon.co.uk/XFX-Series-Power-Supply-Edition/dp/B005TDTV0S/ref=sr_1_2?s=computers&ie=UTF8&qid=1409661562&sr=1-2&keywords=xfx+550w here, what gpu do you plan on getting Upvote 0 Downvote
legend001523 Splendid Jun 3, 2014 7,394 0 29,960 Sep 2, 2014 #7 http://www.amazon.co.uk/XFX-PRO750W-Edition-Bronze-Certified/dp/B0045L4BJ6/ref=sr_1_1?s=computers&ie=UTF8&qid=1409661591&sr=1-1&keywords=xfx+750w or get this if you need extra power Upvote 0 Downvote
C CoolGamerFrost Distinguished Aug 28, 2014 72 0 18,630 Sep 2, 2014 #8 Haha and gigabyte gtx 760 4gb Upvote 0 Downvote
legend001523 Splendid Jun 3, 2014 7,394 0 29,960 Sep 2, 2014 Solution #9 hmm... If you can afford it get the second link i posted, both will provide sufficient power even with a 760 Upvote 1 Downvote Solution
C CoolGamerFrost Distinguished Aug 28, 2014 72 0 18,630 Sep 2, 2014 #10 Yeah OK I'll go with that one thanks Upvote 0 Downvote
