Motherboard for 1060 and i5 4460.
https://pcpartpicker.com/product/YDrG3C/asrock-motherboard-h97manniversary
Cheaper ? : https://pcpartpicker.com/product/qLtCmG/gigabyte-motherboard-gab85mds3h
Cheaper ? : https://pcpartpicker.com/product/9fH48d/gigabyte-motherboard-gab85mds3ha
Gpu Size Should Make U No Worry. It Require Pci Express 16x Slot And The The Motherboards I Linked Supports This Slot . Ur Concern Should Be Ur Case Which If Its Micro Atx Or Atx I Assure U There Would Be No Problem Too 😉
Its Just Dual Fan . It Will Fit And Run Fine 😉
Regards
Regards
