Motherboard for i5-3570k dual monitor?
FreddyF
Hi. I will be purchasing the i5-3570k in a couple of days and also was planning to have a dual monitor set-up. Question is which motherboard should I buy? Price range about $120 - $160. Thanks in advance.
Edit:
Motherboard: Unknown (This is what I need)
Graphics Card: GTX 780 3GB Video Card
And planning on getting this monitor: ASUS VG248QE Black 24" 144Hz 1ms (GTG) HDMI Widescreen LED Backlight LCD 3D Monitor
RAM: G.SKILL Sniper Gaming Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C10D-16GSR
Planning on using this PC mostly for gaming, also some minor video rendering.
It doesn't really matter. The motherboard is not what allows a computer to be dual-monitor. It's the graphics card. Unless you're not planning on having a discreet graphics card.
It's strange to opt for arguably the most powerful gaming oriented CPU and not list a graphics card to go along with it. More of your system information is needed and it's likely that from that info we can help you from making a horrible mistake.
We need:
Motherboard info.
Graphics card info.
Power supply unit info.
Display resolution(s) info.
Also helpful is RAM info
